CPE intake (minus crossover) and Mountune symposer delete
Trader history for DangerMouse (3)
DangerMouse
Rockford
Mountune sound symposer delete, mtc silicone hose w/ mountune clamps
$25 shipped
SOLD. CPE intake. Far from perfect but maybe you could use it.
$140 shipped
-No crossover pipe
-No clamps except tbolt for the bottom air feed tube and filter
-Lid is scratched
-No clips for the hood prop
-Filter is dirty
-Middle pipe has some rub marks
-No screws for lid. They rusted and seized after one winter. Had to cut them and remove the nuts from inside of the box. I used push pins after that. They fit and work nicely but hard to remove without a tool.
Pics are here:
https://imgur.com/a/FXMSl9y
XanRules
Portland
Great price for someone who's handy. Pop a new crossover on, wash the filter, and you've got a hell of a setup for cheap.
DangerMouse
DangerMouse
Rockford
Would the intake fit on a ramair crossover pipe?
I can't say for sure unfortunately.
I did connect a MAP intake to the Cpe crossover so chances are yes it will work. You will need a 2.75" to 3" coupler to connect the two. The cpe intake bends at the end of the crossover and the start of the middle pipe. And uses a short 45 (I think, could be less) coupler. I would get a squirrelly 45 degree coupler from MAP and see if that works. Otherwise you could always cut the cpe middle pipe straight and use a longer leg coupler.
Sorry I can't say for sure.
You could always try cpe and see if they will sell the crossover separate, that might be your best bet.
XanRules
Portland
In looking at my RamAir crossover and the photos of CPE bits, I think it would - you MIGHT need a different silicone coupler but that would be the only issue.
DangerMouse
DangerMouse
Rockford
Definitely need a different coupler. It will fit, just how hard it is I don't know. I don't want to mislead people.
