Transmission Fluid Poll - Which is best for daily driving in mild climates (e.g. Western OR)?
Transmission Fluid Poll - Which is best for daily driving in mild climates?
  • Motul DCTF
    Votes: 13 16.3%
  • Motul Gear 300 75W-90
    Votes: 12 15.0%
  • Ravenol MTF-2 SAE 75W-80
    Votes: 30 37.5%
  • Motorcraft XT-11-QDC
    Votes: 9 11.3%
  • Other
    Votes: 16 20.0%
  • Total voters
    80
anticon
Sherwood
I read through all the transmission fluid threads I could find and it sounds like the options for replacing the stock fluid are the following. Which one is best for daily driving with some "spirited" weekend drives in mild climates?
Motul DCTF - https://www.motul.com/us/en-US/products/multi-dctf
Motul Gear 300 75W-90 - https://www.motul.com/us/en-US/products/gear-300-75w90
Ravenol MTF-2 SAE 75W-80 - https://www.ravenol.de/en/products/usage/d/Product/show/p/ravenol-mtf-2-sae-75w-80.html
Motorcraft XT-11-QDC - https://www.motorcraft.com/us/en_us/home/our-products/chemicals-and-lubricants/transmission-fluids.html
Other - ?
Redline DCTF
Castrol SynTrans TransAxle 75W-90
Ravenol MTF-3 SAE 75W
The 2017 ST Supplement to the manual specifies the following:
Motorcraft® Dual Clutch Transmission Fluid (U.S.)
XT-11-QDC (U.S. & Canada)
Spec No. WSS-M2C200-D2
ST Transmission: Ford B6 6-speed manual with 228 millimeter clutch and dual mass flywheel
JDG
Conshohocken, PA
The problem with a poll like this is everyone just votes for what they use. It is only relevant to those who have tried more than one fluid on the list and have a preference of the fluids they have tried. I use the Motul 300 75w-90 and it is better than stock.
anticon
anticon
Sherwood
True, maybe I should have phrased it as "What transmission fluid are you using or would recommend?"
brbauer2
St. Charles
I just switc6h from stock fluid with 33500 miles on it to the Ravenol MTF-3. I wanted a little thicker than stock while not getting too thick heading into winter (Chicago suburbs).
Immediately felt and heard a difference after the change. Gears slid into place and did so with less sound. Could all be placebo of new fluid though.
Sent from my ONEPLUS A3000 using Tapatalk
No you're not the only one..... I noticed it to be less clunky and like I'm shifting through butter! I use the Ravenol MTF-2 75W80...GREAT STUFF!
TDavis
Columbia
I'll be watching this thread as I am curious on peoples opinions. I don't mind veering away from the Motorcraft oil(theres no harm in it either way).
I got my Trans replaced @ 27k....new Ford fluid etc.....Drained that shit out...put in Ravenol mtf-2 75-80....best thing I did so far for the Trans....shift feel was greatly improved!
TDavis
Columbia
What happened to your trans?
Had a very horrible howl in 4th..started to creep into 5th and 6th gear also.....Ford engineer said don't even tear it down....just replace it. I never really looked at the warranty bill either to see what or of a diagnosis was....[popcorn]
When it comes to temps, oil weight is one of the biggest factors.
For higher temps, thicker oil. Opposite for colder temps.
https://www.fiestastforum.com/forum...n-fluid-change?p=296666&viewfull=1#post296666
OEM Motorcraft weight is a full synthetic 75w-80. That stuff being like water coming out of a transmission that's at garage temperature (65-73F) I went with a slightly heavier, Castrol SynTrans TransAxle 75W-90. Even thought same numbers are on the bottle, it's been my observation that the full synthetics tend to be thinner than mineral and synth-blends.
HardBoiledEgg
Fontana
This forum suggests the wrong fluid so many times
The car comes with DCTF and this forum loves putting gear oil in it
I too followed what people did and went with Motul gear oil, and drove with it for 30-40k
Next I went to Motul DCTF and omg night and day!
I too followed what people did and went with Motul gesr oil, and drove with it for 30-40k
A lot of those "Gear oils" have now been ford approved and spec'd....just an FYI.
HardBoiledEgg
Fontana
Motul DCTF was like butter and still is. Hot, cold, new or old. The Motul gear oil was rough until warm and still was iffy
I also run the Boomba ultimate shift kit so it's as short as possible and already going to feel more direct. But the switch to DCTF made it that much more enjoyable
I use Ravenol MTF-2 75w80....way better than stock trash. Meets Ford spec also...
Link...
HardBoiledEgg's observations are correct. The transmission is designed around Trans Axle fluid and will provide better performance with it.
Go a little thinner or a little heavier, or even non-synth if it's spec, but for best performance you'll want to stick with the same type of fluid.
I will disagree here....manufacturer's look at cost on an assembly line and what's cheapest to stock the most of on the line. When they make multiple parts or vehicles on a line do you think they will keep multiple types of fluid on the line or one that can pass and keep costs down? This isn't a Gt-R or GT-3 production line....its a plant in Viva El Mexico or in England looking to keep costs down. So they utilized their DCTF as they have plenty of it. A Transmission is NOT BUILT around fluid.....that's like saying a turd doesn't smell after you take a dump directly into your hand....no way...they build a part around a computer design and test fluids in them for Thermal breakdown...shear resistance and keep costs down. I'm not gonna get any more BITOG here or preach from Driveline exp. Use anything you want that's within spec of ford and you will be fine...going outside the realm is sketchy....sometimes even call the manufacturer of the persay fluid you would like to use and ask them....not every manufacturer can fit every little spec from all the OEM vehicles on their bottles either. When in doubt....call Amsoil....call Redline....you might be suprised!
Cost savings by reducing stock inventory is actually a point I made in my post earlier. (click the link below) So I'm not going to disagree with myself there.
HardBoiledEgg merely pointed to his experiences with Gear Oil versus Trans Axle fluid.
HardBoiledEgg: "Motul DCTF was like butter and still is. Hot, cold, new or old. The Motul gear oil was rough until warm and still was iffy ..........."
Based on that experience, the Motul gear oil was much more viscous than the Motul trans axle fluid. This might be fine for those living near the equator. But for mild and Northern, it doesn't sound like a good idea. Even with the watery stuff that Ford puts in, my shifter was stiff for a throw or two on the really frigid mornings.
