OK, my question is, why does this make any difference anyway?
It is a proven fact that a car is quicker if you don't spin the tires.
If you are popping the clutch just to hear/see the tires spin you are promoting breakage of other parts.
These little cars today aren't built like the ground pounders of yesteryear.
If the right axel does provide some snap torque as some suggest (although I am not convinced) it would be very insignificant.
Why not just lower the air pressure in the right tire by a pound or two to compensate.
I am not an automotive engineer or a master of physics.
These are just my observations and opinions.
Dave
I think we've certainly gotten off topic. The question was "which wheel spins first"
The answer is "the one with the least traction" because it's an open diff. I really didn't expect this to be a controversial answer. This is not wrong, but neither is saying that an open diff CAN spin both wheels.
Under perfect conditions, you will spin both wheels with an open diff. The amount of traction has to be the same, or at least very close. So flat ground, same amount of weight on each corner, etc.
Why bother discussing it? Well, it's a forum, and it's what people do. As long as we can keep it civilized and nobody gets too upset, i don't see an issue.
For anyone that cares, you can read the science behind open and locked diffs:
https://en.wikipedia.org/wiki/Locking_differential
https://en.wikipedia.org/wiki/Differential_(mechanical_device)#Loss_of_traction
The gist is that an open diff applies equal torque but allows different rotational speeds. Locked is the opposite - rotational speeds are equal, but the wheel with more grip is getting more torque. In off-road applications this is very pronounced, where both wheels are VERY unlikely to have equal traction at any given time, and the amount of traction in general is lower compared to asphalt. You won't get far in an open 2wd in mud for example.
On a paved road this matters less, but still does:
100% correct. Which is why you want an LSD - you will spin less with the same amount of power. It is also a proven fact that a car is quicker if you launch hard instead of leaving from idle. But you can only apply as much power as your traction allows. It's easier to overcome the traction of one wheel than both together. Hence, a car with an LSD will usually launch harder than one with an open diff, all other things being equal.
This is one sore point for me, is that STs didn't come with an LSD
and other than FWD, it's probably the biggest detractor in an otherwise great little car.
Ps. it grabs the brakes on whichever side is spinning instead
Ughh
