Those look promising for $38, and you either read up and knew to get the small fan base ones or got lucky and ordered ones that will fit.
Pretty much all of the lumen ratings are bullshit for marketing purposes, I'm hoping that actual watts isn't faked and these at 30w/side actual is pretty good, but obviously every design is different and still not sure if even actual watt numbers aren't faked either. Pretty much the highest I see is 36w actual per bulb, but these are all things that are difficult to use key words in searches to narrow down, some are listed in total watts actual, total watts halogen equivalent or the same 2 categories but the number is listed just for each side in the title. We are literally forced to look at nearly every single H11 LED listing, look for ones where the fan base appears no wider than the metal connection base, THEN click on it and make sure they are't too wide, try to get at least a 30-36w actual per side, read reviews.... UGH... SMH...
Maybe I should keep editing the original post with ones we've verified to work with "garage door from roughly 10 feet" example pics and a link to where you got them? Hmmm...
Anyway, please show us a garage door/wall shot, I like garage doors as it gives better reference for cutoff, but whatever you can find, thanks for contributing!
