Rear wiper
Near Knoxville
Could someone take a picture or two of the base of the rear wiper for me? I had a Saris bike rack on the back and accidentally hit the rear wiper stalk. It stopped at 12 o’clock when it hit the top support arm. It seems to be working ok, but I wanted to make sure I didn't knock something out of alignment. I know, I should have pulled the fuse and I will next time! Thanks.
Sanger
If I could find a company that makes a rear wiper delete I'd get that since I don't use it anyway.
I just used a plastic clip that i had laying around with some black silicone to seal the hole when i deleted my rear wiper
TDavis
Columbia
Was it like the black plastic christmas tree push pins?
Sanger
The plug i used was from the heat mat under the hood i have vents so i removed all that and used one of those plugs
Lecco
I've deleted the wiper motor, keeping the original wiper fixed with a nut and bolt. So I didn't have to put any plastic cover.
PunkST
Menasha
Ron has a whole delete panel if you want to really clean the looks up. I personally need mine because of the climate and snow.
