I guess you missed the part where a larger diameter bushing helps absorb NVH while also being much stiffer than stock does REALLY help... I have almost zero wheel hop with my large diameter Torque Solutions 75a so not sure how you can make the comparison unless you've tried them... Also, there is only so much a RMM can do before other factors come into play, sometimes you can go too stiff for no returns on performance, only more added vibes.
The revo mount has a stiff and large diameter bushing. Between shifts it's great but you can still make the engine rock when decelerating in a gear then go to WOT or near WOT. With the AWR 88a, this is not present. I'm certain with the milder end of the mounts (I've had most of them) including the Torque Solution, this engine movement is present. Again, the further up the scale you go, there are benefits you just have to decide how much interior "discomfort" you can manage or care about. We know you love your TS mount Dan, nobody is hating on it or has a poor word to say, I actually added it to my site because of your continual rave reviews
