Your kinda close. I'll try to explain it as best I can at the moment but I'm still learning as well.
The wastegate actuator is mechanically attached to the internal wastegate flapper valve, which is located on the exhaust side of the turbine. When that flapper opens it allows exhaust to bypass the turbine, limiting speed of the turbine, which also limits the boost created on the compressor side.
The wastegate actuator is a linear actuator made of an internal spring and diaphragm. The electronic boost solenoid allows boost pressure to be added to the top of the actuator, pressing on the diaphragm and the spring, which increases pressure applied to the wastegate flapper. As long as the flapper is closed, the turbine will spin faster, creating more boost. So, the wastegate flapper is held closed by mechanical spring pressure and boost pressure applied to the diaphragm. You can customize the wastegate spring to achieve your minimum boost level which occurs when the exhaust flow overcomes the spring pressure applied by the wastegate actuator without air pressure applied to the diaphragm.
This is a baseline tune so we're running purely on spring pressure so we know what base boost we are starting with. Spring pressure plus preload should yield an expected boost pressure, which we are not at just yet. For example, 11psi spring + preload of 3mm should yield 13-14 psi according to my tuner.
Currently, I am seeing around 12psi on my 3rd gear datalogs.
