Are you talking E30 or a higher ratio of ethanol? You should not need the injectors unless you intend to go above 285ish wheel horse power. The limit of those injectors state that it can be ok til 420 Brake Horse Power. which is 350ish Wheel Horse Power.
If you want more, then throttle body or port injection will be required. So, if you don't intend to go over 350 WHP the injectors will be a cheaper alternative. But if in the future you want to go mega horsepower, you will now spend another $880.00 plus. Buy once, cry once.
