Ok, so the sample is here! We have good news and bad news. First the good news. Turbo looks awesome! We are stoked on how it came out for a production sample! Bad news, they totally screwed the pooch on the cast inlet. They did not make it large enough, and they have to retool to make it correctly. All this means is, we will use a readily available big mouth inlet for testing until the new cast inlet is ready. There is no need to hold up turbo testing waiting for the inlet, a 2" opening is a 2" opening. As long as we are not restricted by the factory inlet elbow, we can get results without worry of restriction.
Ok here is a bunch of photos. As you can see, the turbine wheel is not some 12 blade inefficient wheel that is clipped in hopes of getting more flow through it. It is a 9 blade design keeping the full-back inducer, just much larger. This will keep the aero of the wheel intact, and allow for much more flow, and quick spool. The stock wheel actually fitting in the exducer bore of the new housing...
Compressor wheel looks great, castings all look great. We are happy with this unit as a sample.
Next move is to get it to the guys over at Panda, along with the aftermarket inlet elbow, and let them get to work trying to break it. Stay tuned.....
