I highly recommend you head over to the fusion forum for your deep read about forscan
First I have to say ForScan on your phone only will data log but using a PC you can turn off/on options just buy flipping a hex bit.
I noticed fiesta does not have a big post on this just little ones on small topic so as you share here I will be updating first post about the possibilitys using ForScan.
I am not a good organized person with spreadsheets so if anyone would like to start a calaborative spreadsheet I'm sure that would be appreciated.
I highly recommend using a obdlink mx Bluetooth or wifi device wifi only for Apple unless you are jailbroken. These for ease of use if you also enjoy using torquepro but if you want to get more serious about quick data logging and piece of mind that you won't have issues when flashing a change you can get a obd to USB device that needs to have a switch to access both the hican and mscan.
REMEMBER TO BACKUP ALL YOUR ASBUILT INFO BEFORE MAKING CHANGES
Makes it easy to return to unmodified for dealer service and if something didn't work
Download ForScan/register for license.
http://forscan.org/download.html
Even though every vehicle I have seen have the same modules the same codes are usually not universal but is worth a try if you have the same module
