The 245 will still be stretched on the 9" rim, and from what you're saying the rim is further away from the strut than stock. This tells me the 245 should clear fine.
Also consider overall diameter and how low you want the car, and any possibility of the height of the tire causing interference with the bottom of the spring/spring perch.
I'd go with 245s. But I dream of 18x10s with 285/30s and a slightly wider flare.![Big Grin [biggrin] [biggrin]](/images/smilies/biggrin.gif)
