Sup guys parting ways with my coilovers. There in perfect working order with everything included for a simple install including the spanner wrenches. This set up has about 5k miles... $480 shipped
Info
Spring rates: Front: 5 kg/mm / Rear: 3 kg/mm
16 precise levels of damper adjustment
Koyo Japan 6204z bearing
Polyurethane bushing (if applicable)
Monotube shock design
Anodized shock body
Lightweight aluminum shock body and T7075 forged aluminum / carbon steel brackets
52mm carbon steel shock body with a performance internal piston
Independent ride height and spring preload adjustments
Race shock oil with a high viscosity index
1 Year Warranty from Date of Purchase
SpringFront Rear
Rate (kg/mm)53
Length (mm)200180
I.D. (mm)62 62
Camber Plate NoNo
Text me for faster response 805-416-3019 chris
Info
Anodized shock body
SpringFront Rear
Rate (kg/mm)53
Length (mm)200180
I.D. (mm)62 62
Camber Plate NoNo
