Cant find a thread addressing this besides typical 5k mileage oil change need some input if this seems normal ?really need this clarified if its normal on the fist ,so my 2014 fist has 50k miles and during oil drain found metal flakes inside ,will post pic seems its not jist to my particualr car my brother did his oio change on his 2015 fist with 17k miles and found the same result any ideas os this normal cant find a thread both car seem way over break in period ??
If you can visibly see the metal "sheering" in the oil, just think about how much of that gets redeposited on moving parts. This is a big reason it is beneficial to change the oil several times before the 1st recommended oil change interval. I changed mine at 100 miles, 500 miles, 1,200 miles, 3,000 miles and 5,000 miles and then 5,000 miles ever since. Last several Blackstone oil analysis shows ridiculously low particulate in my oil, even when it is at the change interval schedule end. Some people say changing the oil more often is a waste of money, but in my experience you will end up paying for it in parts and labor later (usually after the warranty runs out). My car has 43,000 miles on it. The oil has been changed 13 times. I've also changed the transmission fluid twice, coolant once, power steering fluid once, brake fluid once. Runs perfect, makes really good power on the dyno, and still drives like new, no leaks, no failures, no gear noise or what I call driveline "slack lash". It's been stage 3 most of it's life.
I'd get that oil out ASAP.
