The stock stereo on my 2016 FiST was plagued by electrical noise and distorting tweeters (b/c of resonating door panels), so I deleted it and installed an Alpine deck in the glovebox, a 4-channel amp under the passenger seat, a 1-channel amp under the driver's seat, and a 10-inch subwoofer in the hatch. In the process, I decided to delete the center console/armrest. I did this to make wiring easier -- the amps ground to the chassis in the area vacated by the center console -- but also to remove wiring and other bits I deem unnecessary.
Removing the console is fairly easy, as it is only affixed by two bolts and two screws, though you have to pull off the dash trim over the HVAC controls and remove the plastic housing surrounding the gear shift. For details, Boomba Racing has an install video for a product that requires removing the console here (removal starts 50 seconds in).
Inside the console is a wire loom containing (1) usb wiring; (2) wiring for the 12 v "cigarette" lighters; and (3) the ambient light module and associated wiring. I unloomed everything and deleted (1) and (3).
I covered the gap between the front seats where the console lived with old floor mats that I cut to shape. Since the mats are very stiff, I was able to glue together a sort of two-sided wall to cover some of the bare metal of the emergency brake. I then affixed two nuts onto existing threaded posts to hold the material in place.
Here are some photos.
This is the majority of what gets deleted, including the usb wiring and the ambient light module and wiring.
This is the cover I glued together out of old car mats.
Top view of cover in place.
Secondary view of cover in place.
Top view of console delete area without cover.
Secondary view of console delete area without cover.
Detail view of console delete area without cover.
1-channel amp under driver's seat.
4-channel amp under passenger's seat.
