Having recently upgraded to X47 I am learning a few things about the true investment required for this or presumably any turbo upgrade. Thought I'd share to maybe help others plan in advance. Feel free to add anything I've missed.
WHAT YOU KNOW YOU NEED
Turbo & elbow
FMIC
Downpipe
Accessport & mount
Tuner
Gaskets/hardware/etc.
WHAT YOU SHOULD PROBABLY GET
Intake
Exhaust and hangers
RMM
HIDDEN OR LESS-KNOWN COSTS
Upgraded diverter valve
Upgraded plugs
Upgraded waste gate actuator
Upgraded charge pipes
The valve, in addition to helping hold boost, is great for eliminating pesky low-rev venting noises. I am finding the charge pipes necessary as my hot side OEM pipe blew loose last evening. The stocker is pretty flimsy and flexible.
So these "hidden costs" might be obvious to some but maybe not. Depending on brand, all four of the above will run $550+. In all my reading of the various upgrade threads there wasn't too much talk of these, probably because people already had them or because needing them was a given. Coming from a full bolt on minus downpipe setup I had none of these.
Anyhow think about adding $550ish to the budget if you're planning an upgrade and didn't plan on these things. I'm a planner and didn't do enough homework so I've ended up spending a bit more than planned. Well worth it of course.
Turbo & elbow
FMIC
Downpipe
Accessport & mount
Tuner
Intake
Exhaust and hangers
RMM
Upgraded plugs
