A general guide, exact procedure may vary according to model .
Tools needed. Torx wrench set. Plastic panel removal tools and patience .
Also, 10mm socket, extension and ratchet.
Good Write up Sek. Those tools are a must if you do not want to scratch paint behind the panel. They can still damage the plastic though, just be careful to anyone else doing this.
You can remove the Door Arm Rest section by removing the melted over tops of the plastic studs.
I did this to replace the fabric with leather.
I wrote the complete procedure that is posted on RedlineGoods web site.
If you have any questions I will be happy to help.
I am just wondering if we can replace our door panel with that door panel since I've read the door pull tend to break off on ours. I guess the 3 door version of the door panel is longer so that's out of the question.
Dave, this is exactly what I'm looking for as I'm about to get the armrest/center console and front door upholstery in leather. I checked their website but I couldn't find your write up easily. Would you mind posting a link here for me? Thanks so much!
