After our last group buy, I have about 14 of these flashers ready to go by the end of the week. This is for those who missed out on the group buy. These are made to order, once you send payment let me know what speed of flasher you would like.
Asking only $4 more than the group buy price of $40 shipped.
Why do I need this?
- Grabs drivers attention, responding faster to quick braking
- Reduces chances of other drivers tailgating, lowering your chances of being in a rear-end collision
- California DOT recently required all dealerships to offer a 3rd brake light flasher module on new vehicles
How does it work?
There is a microprocessor module with 3 wires, power, constant power and a ground. The module detects when you brake and causes the brake light to flash 3 times before going solid. After being off the brake pedal for 5 seconds it will flash again when you apply the brake pedal.
How do I install it?
All you have to do it use a T20 torx bit to remove the 3rd brake light from the spoiler, pull out the wiring, cut the power wire (blue/white) a few inches away from the light connector, splice in the black power wire to the vehicle end of the power wire, splice in the yellow power wire to the connector end. Use the bullet quick splice to add the connector to the black/purple ground wire, squeeze closed and plug in the black wire from the flasher into the quick splice connector.
How does the flashing sequence work?
For those wondering how the flash sequence works, check out the videos below to see the difference between the slow and fast flash speeds.
Slow flashing
[video=youtube;IZ9UdnDnZGY]https://www.youtube.com/watch?v=IZ9UdnDnZGY[/video]
Fast flashing
[video=youtube;KbBV7mQGQ9c]https://www.youtube.com/watch?v=KbBV7mQGQ9c[/video]
Installation video courtest of [MENTION=38722]mcflyin619[/MENTION]
[video=youtube;4RQ9NYyu2z0]https://www.youtube.com/watch?v=4RQ9NYyu2z0[/video]
