As a lot of you know I was the first to bring in and test the X37 turbocharger. Dealing with the manufacturer proved to be difficult and had to haul all sales. I have been quiet, but busy. Since the day I removed the X37 from the website I have been working on a new turbocharger with a manufacturer we have been using for a few years now.
This turbo will not require you to send in your OEM core, you get to keep it. Why? Because we are recasting the factory turbo with bigger housings to fit bigger wheels, the CORRECT way to upgrade these turbos. The factory housings really limit what you can make for power on these cars, so we made sure to eliminate that restriction. This allows us to upgrade both the turbine wheel AND the compressor wheel, no clipping/cutting/modifying the stock wheel a TRUE turbine wheel upgrade without sacrificing spool.
Still 100% bolt-on, and not in a sense of ATP "bolt-on" this is a true bolt on. Connections for Manifold, Downpipe, Intake, Oil Lines, Coolant Lines and Chargepipe are all in the factory locations. Just everything internally has changed.
This turbo is the brainchild of Vargas Turbo Technologies and TUNE+. We have collaborated in the past to make the best performing stock frame upgrade for the 2.3L Ecoboost Mustang, just recently the Focus RS, and the newest being the Fiesta ST.
TUNE+ will be the sole distributor of this turbo upgrade once released. We will have a few select dealers for the product when the time comes. For now the two below dealers are the only approved dealers for this upgrade.
-Deadhook Motorsports
-Panda Motorworks
I wanted to work with the companies above to make sure that all customers have a good relationship between the turbo offering and their tuner. This way if there is questions we all can work together to answer them, this will also prevent a war between two turbos like the Pumaspeed Vs Cyborg. In my opinion those battles were tuner fueled. This should alleviate that.
There will NOT be a pre-order for this turbo until production is nearing completion. The ETA for production to finalize is about 2-3 months from now. I know it is a long wait, this is why we are not taking pre-orders. We want to make sure that these are en-route to us before we accept a single penny from a customer.
There will be three options offered so it will cover a wide range of goals. If you never plan on using any fuel but 91/93oct The Stage 2 is for you. If you are looking to run E30, Methanol, or both the Stage 2+ is your turbo of choice. If you want all out power, running Aux Fuel and E40/E50/Race Gas the Stage 2+ MF is your baby.
Here are the three options:
Stage 2 good for around 300WHP (tuning / fuel dependent) Stock spool
Stage 2+ good for around 325-350WHP (tuning / fuel dependent) Stock spool
Stage 2+ MF good for around 350-375WHP (tuning / fuel dependent) 200-300 RPM hit in spool
Pricing is outlined below, remember this doesn't require you to purchase a core or provide a core.
Stage 2 with new actuator, and inlet tube $1499.00 Shipped
Stage 2+ with new actuator, and inlet tube $1599.00 Shipped
Stage 2+ MF with new actuator, and inlet tube $1699.00 Shipped
The compressor inlet has been enlarged to 2.00" and will include a CAST 2.00" to stock intake style connection so you can use any intake on the market, including OEM.
Here is a comparison of the wheels going into this hog!
If you have any questions, please ask. We will reply when we can. We are EXTREMELY busy right now with our new shop in Texas so we don't get much time to get on the forums but I will update every so often and mass-answer all the questions!
Cheers.
