I got new wheels today, switched my TPMS sensors over, and can't get the TPMS light to go out or the sensors programmed to the new wheels. Have others been able to successfully transfer the oem TPMS sensors to new aftermarket wheels (TD Pro Race 1.2s in this instance) ? Each sensor was reinstalled in its original position on the car.
I asked about this before I got the wheels and a number of sources said you can switch them, my car and oem wheels/sensors are new, 2700 miles on them. The shop was a high end tire shop with the Hunter Road Force balancing machines you want, recommended by a car buddy, with lots of high end and performance cars on the lot. They said they had never broken a sensor, but that they would make it right if they did.
When I drove off, the guy said after a mile or so the sensors would reinitialize and the TPMS light would go out. It didn't, so I swung by my dealer. They tried a Ford reset tool and a generic one and both said that two sensors were inactive. The light stayed on. When I got home, I tried the reset procedure the ST Manual shows for after rotation: put in programming mode, let air out in sequence until the horn blows, 1 beep for success, 2 for not so much. It didn't work, pumped them back up (the Ford manual reset procedure is a hassle btw.)
This ruined my excitement at getting new wheels, although the wheels themselves look great.
