Hello All,
I am looking for summer tires for daily driving and autocross to fit the new 16x7 Sparco Assetto wheels I just purchased (42mm offset). I am looking for tires that fit the following criteria:
1) Use as daily driver in dry/wet conditions and also for occasional autocrossing
2) Looking for good grip and decent mileage (do not need ultimate grip)
3) Summer only (I will be running a dedicated winter wheel/tire setup)
4) Hoping for >10K mileage out of the set
5) 16x7 wheel
6) < $150 /tire
I think that I would prefer a 205/50R16 due to the added sidewall versus a 205/45R16 but would be open to getting thoughts on both sizes. The roads aren't the best here in PA and I am hoping to make the ride a bit more forgiving without sacrificing the exceptional turn in of this car.
I am also curious what width I can run given stock ride height. I am eyeing the BFGoodrich G-FORCE SPORT COMP-2 in 205/50R16 but they are 8.3" wide mounted per tire rack.
Source:
https://www.tirerack.com/tires/tire...R6GFSPC2&vehicleSearch=false&fromCompare1=yes
Will a tire that 3/4" wider than stock still fit?
I appreciate any thoughts you guys may have!
5) 16x7 wheel
6) < $150 /tire
Source:
