The pulls on Youtube are my car, in Mexico of course. No formal dyno and I dont run WOT in 1st to preserve the axles and side bearings in the transmissions, the known weak points for these cars (aside from leaky axle seals even stock). Vdyno from yesterday, SAE, adjusted for temps and barometric pressure incorporating altitude adjustments are shown here. From real world, closest I can tell you is it runs about a half a car length to 3/4 behind my buddy's from 40-110mph and he has a larger turbo and a true dyno of 305whp/290wtq on pump 93, about 350whp on E40, redlines at 7250. My car is a wee bit lighter, about 100lbs but I kept the rev limiter at 6600, so that accounts for some of the variables. We ran with him at 93 octane and myself at my E22 blend. I would say I safely am at 280-285whp which is great for this little beastie. Youtube videos are about the same temps as our runs fyi. I will say that at below temps in the 60's, the car sometimes nips mid-290's to barely 300whp is the highest I have seen. When you get to 85-100 degrees, vdyno's are in the 270-275 range. Very safe as requested of Randy.
Red (3rd gear) and blue (4th gear) are two days ago runs, as you can see very consistent with a good log. Green is with temps at about 44 degrees a few months ago. The torque is overestimated due to a bit of wheel slip at peak torque for the cold run, but its easily 10hp over what it is right now when you factor out that hump. E22 blend for all the runs, about 94.5 octane, but no additional timing over 93 maps explaining why they arent higher. I just wanted the safety net for knock/etc, fueling is adjusted accordingly. This is on the non-billet WGA fyi. Regarding the weight (asked previously), back seat is out, spare is out, lightweight wheels and brakes, lightweight battery, washer reservoir removed, but intercooler is a bit heavier. Weighed in at 2580 without me in it. I am 175lbs.
https://www.youtube.com/watch?v=lf3RDxGcBiI
https://www.youtube.com/watch?v=Yd2hmPfoOB0
https://www.youtube.com/watch?v=uOfj5196CRo
