i am a noob. Can you explain a little better? I don't even really know what everything looks like by the turbo so I'm having trouble following you.
Ok the cpe intake comes around between the engine cover and cowl. When it turns down towards the turbo normally there's a 90 degree coupler that attaches to the turbo and points up to connect to the intake. Then you install the mrx it does align perfectly and sits in a different location than the stock turbo so if your not using a stock intake you have to adjust.
With the cpe intake the tube that connects to the 90 degree elbow is short of where it needs to be.
So you have to connect them by making something.
What I did was went to napa, go a 3" truck radiator hose. Really nice and cheap. Then I had him cut at napa one metal pipes about 4 inches long that would fit inside the 3" radiator hose so I would have something to clamp to. Then I clamped down the metal tube I just cut then inserted into 90 degree elbow that was attached to the turbo.
The I inserted the cpe tube into the 3" truck radiator hose and clamped it down
The end of the cpe tune has a bend in it. Just leave it and rub a fingers worth of petroleum jelly on the lip of the tube and it it will go right in and clamp it down.
Does that help
