Auto dim Second Value?
Hey all. Having a camera is awesome... But... Auto dim no longer working is slowly driving me crazy.
With that being said, i have been brainstorming a couple ways to hopefully find an end to the issue...
I pulled the AB's from a 2016 Titanium with the backup camera and a 2016 SE. For some reason i could not get As-Built.exe to pull any APIM information for any 2015 Titanium VIN to compare against my OEM ST AB...
Anyways - 2016 Titanium vs SE show more then just the first field being updated. i couldnt figure out what MFT system the Se Used... but it looked touchscreen. Couldn't locate it on the ford service site either... VIN was 3FADP4EJ0GM148197.
Figure If 7D0-01-01 is backup camera settings, im not sure what the difference may be.... Regardless for that particular APIM, data sets 1 and 2 were both changed...
Vehicle Num, Module Address, Data1, Data2, Data3
SE - 1, 7D0-01-01 APIM (APIM), 2130, 6404, 0092
Titanium - 2, 7D0-01-01 APIM (APIM), 2330, 6505, 0096
Would anyone be willing to try updating the other fields?
And then there is CanOpener... Initial cost on this one is a bit high for the experiment... Apparently people have been reporting that this gets the AV working fine, without the auto-dim issues. I was thinking about reflasing my APIM to OE, and then using the CanOpener. After thats said and done, compare both AB log's and see if any other APIM data was changed...
EDIT
So i was able to make out the majority of AB data for the 2015 Titanium reading it strait off notepad
For APIM 7D0-01-01:
The 2015 Titanium shows 2330 6105 c052
my 2015 OEM ST shows 2130 6105 C050
Is there anyway to determine what the xxxx xxxx xxx2 update could possibly change before writing?
