And me as well. The lockpick or the harness found from 4dtech can save you some headach to attach the camera. $50 is not to bad for that. The activation of the feature is very easy via Forscan and is really the cost of an ODB reader ($30 buck for a switch ELM327)
It should work as it works on 2016 and 2015. Reason this is important is the SYNC version changed from 2.x to 3.x in 2016 yet the function to turn it on remains the same. IT is also the same across multiple vehicles.
So I ordered the 4dTech Canopener and harness. Installed it on my 2017 FiST and it works beautifully. WITHOUT the side effects (night/day not auto switching and auto-dim broken) that come with modifying the module yourself with Forscan. Everything works and I now have a perfect backup camera that looks and works like the factory unit. Worth every penny.
I can't find the one write up of the guy who bought a license plate camera where he hard wires it to mft and enables it with forscan. Anyone have the link to his write up? My stuff just came in and lost his page. Thanks!
You be willing to pull the forscan as built log, so we can compare the changes? Im curious what else needs to be changed to maintain the auto-dim functionality. I would consider purchasing the cable for you, if you would seriously consider.
Running the wire for the camera was not fun. Wire coat hanger was needed to feed the wire through and around the hatch and rear window. PITA. Took an hour and a half to get it right. Power and ground are supplied from under the dash. Harness plugs right in to the head unit. composite video plugs in to that from the camera.
