Installed the B8s this morning, Three hours with the dog helping. Easiest struts I have installed. Length of the front from spring perch to top of shaft is 3/8" shorter than stock, rear shocks are almost 1" shorter than stock. Installed the ride height is the same as stock. With the wheels hanging free the droop is the same as stock in the rear.
Took a short drive, the B8 I guess to have more damping than stock. The ride is still very firm, but it does smooth out some of the small sharp impacts that you get from broken concrete. If ride quality is your main concern this may not be the best option, handling is still excellent. I will have to drive more before I can say more.
