Thread Starter
#81
Had a little chance to really test them out today. It's drives like a completely different car. On rails is an understatement. It is solid and planted, you point the wheels and it goes exactly where you want it. Corners very flat, without any unsteadiness. Bumps in the roads are absorbed way better than the stock combo.
Will need to fiddle around with a few things once I get a warm day again. On the passenger side I noticed I had to draw the stabilizer link onto the strut with the bolt. The shaft kinda angled up and didn't go in with just a push like the driver side. The passenger side also sits just ever so slightly higher. Which I noticed as I was torquing everything down that the bottom spring end kinda over shot the rubber isolator. The rain started to some down so I left it for another day.
Yes, my stabilizer bar did the same thing. I just jacked the hub up so that it was even again.
