My fault for asking... Ha
The reason I asked though is because of two things I've been personally struggling to wrap my head around, and that is - how does the amount of side wall (read: stiffness of the sidewall if modeled as a spring) and wheel weight affect the ride when running an aggressive damping profile (which the B6/B8 presumably would do)?
WHY? (And this refers to my previous post where i said there were other reasons... here the are) If you really search through the BMW forums you will occasionally come across a sour review of the B8s with either an H&R or Eibach lowering spring. I may be overthinking it because most are very commending and positive, like
this one, but it still got me thinking, you know?
- On my jetta I had plenty of sidewall and the oem wheels were quite heavy. The spring was stock = linear. The B6 shocks I ran were valved specifically for the OEM spring. The ride was fantastic.
- On the (stock) fiST there is very little sidewall and the wheels are quite heavy. The stock spring is linear. The B6 valving would be slightly short of perfect since not tuned specifically to the OEM spring, but still very close so lets assume insignificant... What would the ride be like? Would the rubber band tires and lots of damping result in a ride that is a bit too 'harsh'?
- Lets say the wheels you are looking at about the same weight as the stock ones and same size, then how would the added spring stiffness (from the lowering spring) and progressive spring rate affect the ride of the car?
- Lets say your wheels are in fact lighter than stock but still the same size, how would less wheel weight affect the ride? Is too much damping for any given wheel mass a thing?
I wish someone who can account for these differences or knows suspension theory would take the time and explain these things in greater detail because I sure as hell can't, instead am stuck here hypothesizing about something I know little about. LOL
BTW agreed about the 5-spoke design, as the multi spoke don't look nearly as good were they a larger size...
