After warm-up engine temperature is a constant - most modern engine are happy at 212F or 100C and then stay within 5 degrees of that.
In any case, most of the engine wear happens when the car is warming up, so that is the most critical period for protection. If most of your driving is with a warm engine at highway speeds in a warm climate (or if you use it primarily as a track car), a 5W-30 might be appropriate, but otherwise I don't see why it would be worth going against Ford's specs.
