hey guys! about to do this, ordered the hub from my dealer.
Does anyone know if this reduces the lag from phone to headunit for audio streaming?
Or does anyone else have that issue? there is about a second or so delay in what the phone sends to the car and what the speakers play via usb and bt. I use plenty of bt devices and this is the only one that does it. It makes watching any sort of media through the car speakers a real drag (when stationary of course)
If this update fixes that then I'll do it asap, but if not i'll wait till my hub comes in.
Every time I ever played anything via bluetooth it has not sync'd with video properly (Accept the apple tv for some reason).
I thought that was a side effect of bluetooth honestly
I figured it out, you need to turn it on in the settings menu. All good here. The nav is nice. And it doesnt kill your battery because the phone is plugged in.
Try going to the drive in file finder. Right click it. Hit format. Then make sure its fat32. Then make sure you right click the file 1 and hit extract all and select the drive. Dont drag and drop. And make sure you format the drive. Don't just delete everything manually.
Im not doing something right. Not too sure what it is.. same message.
All im supposed to have on the flash drive is the "syncmyride" folder and "autoinstall.lst" correct? or am i supposed to take the 4 files out of the "syncmyride" folder and have them as individual items
I use Bluetooth headphones every day with my iPhone and YouTube videos work just fine. In the Volvo xc90 it works fine too. Just the fiesta do I have this problem. And I'm curious but what Bluetooth is your apple tv doing?
But i have the file from the link on the first page. Im right clicking that file, extracting all(putting it straight into the flash drive) and i should be good to go, correct? Any other steps
Also, now that its done i have the read me and the upgrade file. but even though i extracted it and moved it to the flash drive.. its still zipped? but the files inside are not zipped.
