I sealed my FSWerks exhaust with Carbon Collective and spent way too many hours polishing the entire system before installation to increase the surface tension in order to reduce the ability for the corrosion to start. I wash my Fiesta weekly and use a pressure wand to rinse the underbody with hot water. This weekend I noticed that my FSWerks tips are starting to get corroded. Some of that may be metallic particles from brakes mixing with the road salt creating a surface stain. I don't remember this happening with my Borla system on the 2011 Fiesta, but that had very different brake pads and rear aero.
This is what I have used in the past to clean exhaust systems in the springs time;
Brass (not steel) wool mixed with Mother's mag wheel polish
Apply the polish with a rag (after the system has been cleaned with soap/water and dried)
Use the brass wool to work the polish into the metal and remove corrosion
Remove polish with a rag
Repeat polishing, but only use a rag to apply, polish, and remove
