Items Needed:
1) Small flat head screwdriver
2) 12961 LED Bulbs
Step 1 - Use the small flat-head and push back the clip and lift at the same time.
Step 1-B - If you have a hard time lifting it up, you can use a dull butter knife after pushing the clip in.
Step 2 - Remove the bulb housing.
Step 3 - Twist and remove the bulb from the housing.
Step 4 - Remove the old bulb and replace it with the new one.
Old bulb compared to the new LED Bulb.
Final Results.
2) 12961 LED Bulbs
Final Results.
