PumaSpeed X-47 Hybrid Turbo Thread
How many have purchased / installed / tuned the x-47 Hybrid Turbo?
  • X-47 Purchased
    Votes: 53 74.6%
  • X-47 Installed
    Votes: 18 25.4%
  • X-47 Tuned
    Votes: 12 16.9%
  • X-47 Dyno / V-Dyno Results
    Votes: 8 11.3%
  • Total voters
    71
Given our altitude, i expect a little more lag than most. It's also a lot cooler though, so maybe we'll make up for it a bit on the top end.
shouldbeasy
3% loss every 1000' (330m).
So ya, I expect we'll be down 10% comparatively.
Air at higher altitudes gets thinner, and thus contains less oxygen. So for the same volume of air, you will be compressing less oxygen than at sea level.
DHM1
91oct+E30+Meth(50/50mix) Next couple weeks I will be hitting a real dyno. Will see how accurate these vdynos really are lol
3 fuel tunes.
What do you run for wmi? Also what size jet? It should be a richer afr than it is. It's not my place but I see room for improvement.
Russ
BoostBumps
BoostBumps
Thread Starter #307
Ish's PumaSpeed x-47 Hybrid Turbo Results: E30 (91ACN) + Meth (50/50)
FORUM NAME: Ish
TURBO: PumaSpeed x-47
ADDITIONAL UPGRADES: Injen Intake, 2j-Racing DP, MBRP Cat-back, Mishimoto J-Line FMIC, Turbosmart IWG, GFB DV+
FUEL: e30 (91ACN) + meth (50/50)
DYNO OR V-DYNO: V-Dyno
TUNER: Tune +
RESULTS : 311whp / 313wtq (3 runs averaged) - 316whp (max)
Results above added to 1st page of thread...
http://www.fiestastforum.com/forum/threads/11791-PumaSpeed-X-47-Hybrid-Turbo-Thread
BoostBumps
BoostBumps
Thread Starter #308
Pumaspeed x-47 Hybrid Turbo - e10/91 verses e30/91 verses (e30/91+meth 50/50) Comparisons
Thanks for posting [MENTION=4033]Ish[/MENTION]!
Sourskittle
Russ
I was thinking the samething ( not that I know anything about wmi ), but I was going to "let god sort'em out" since my help is insulting to some...
Ish
Russ
Im running that boost juice 50/50 mix. Started out with a 500cc jet and ended up with a 1000cc.
DHM1
Do your self a favor and get a can a VP M1 and distilled water. Mix it 50/50. It's $40 dollar cheaper than boost juice and it's works 1000000x better. Also it's actual methanol not glorified washer fluid. With this mix at 375whp we keep afr 11.9-12.2
Just trying to help.
Russ
Ish
Russ
I was told the same from Stephen, just couldnt find a place locally that sells VP Methanol. I paid half price for the boost juice so it aint a big deal. Maybe once im out ill try ordering some VP meth online.
BoostBumps
BoostBumps
Thread Starter #319
Looks like the closest VP Store / Retailer is either Temecula or Corona??
https://vpracingfuels.com/find-a-dealer/
