check your levels/gain on the amp. you might be clipping. I've seen some amps very sensitive to clipping and shut off the output channel. does it still happen with the volume at the head unit at 0?
also check ur ground if you used a bolt from the body and not the negative terminal. body grounds should be free of absolutely all paint.
And finally, your speaker wire to the sub should be no thinner than 8 guage. anything thinner and ur pushing it, imho.
