Guys, I don't think the coolant leak thing is going to be common at all. If it's not leaking, it's prob not going to.
The China bearing housing come with slightly different crush washers than the factory ones too.
Two guys have had that issue. But I don't see it being a common thing.
You guys def should give Pumaspeed a heads up that it happened though, if you can... and if they listen.
But if I were an issue with one of my customers, I would need/want to know about it. And if no one ever tells them, they can't look out for it.
But if you have an X37 and haven't been losing coolant, it should not be an issue.
The bigger issue to me is that the guys that had problems, had to go at it alone without any support...
