Oh, the internet and forums! Thank them for recommending Sea Foam, scorn them for being so unknowledgeable.
Sea Foam is a 100% blended petroleum oil product, so it is an OIL product, NOT A CHEMICAL like available retail oil system "FLUSHES" are.
Originally formulated and marketed starting in 1940 to cure problems in fuels and oils commonly occurring in the small engine industry, it is unique because it is OIL. Unique because you can NOT damage internal components when Sea Foam is used within the parameters printed on the product container and available on the internet.
This 100% OIL blend is specifically for drying moisture in gasoline gas/oil mixes & Diesel fuel and oil (yet not a chemical), adding lubrication to fuels and other lubricants for protection, cleaning fuel and oil residue back into liquid, cleaning carbon deposits off cylinder heads, pistons, valves & ring lands, and stabilizing fuels for up to 2 years.
NO CHEMICALS!! No affects on plastics, rubber products,gaskets, o-rings, seals or other components.
Used as a pre cleaner to doing an LOF service or as a "Quick Cure" for minor oil residue problems, Sea Foam can also be used as an after service additive to continue to re-liquefy old oil residue and keep moisture out of your oils. Sea Foam does NOT thin out your oil, has no affect on its lubricating properties, and works with synthetic oils also.
As a pre service cleaner or residue quick problem solver, always drive the engine a minimum of 30 minutes before doing your LOF service.
After putting Sea Foam into your crankcase at recommended amounts, Monitor the oil for color and clarity to determine when an oil service should be done, since Sea Foam is a high detergent cleaner, your LOF service WILL be necessary sooner than normal until residual old oil residue is eliminated.
