FS: 2014 ST, street/track build, $25k+ invested in mods, just asking $15,900!
Sunroof, NAV, Recarro Package, 21,000 miles on car, never drag raced, only 2-3 hard launches ever and just two track days in 2014.
NEW PRICE, $15,900 with everything listed except a few options available as well.
In the process of swapping to a 2016 engine due to blown head gasket on orginal engine caused by coolant hose clamp coming loose.
Only tracked two days with the first cyborg turbo and had quite a few tuning runs due to 3 different turbo upgrades but most of the miles are from cruising only as I rarely drive hard on public roads. My eyes are not working well enough to track the car any longer so I just need to part with it but will sorely miss it for sure
I will consider major part outs with stock or mild mod parts in trade on the complete turbo setup, intake to exhaust but that will require serious effort on both parties due to the highly modded nature of this car. Others are complete IC/ bumper beam/ radiator,/oil cooler, BBK with moded rear axle, 15x9 wheels and tires. perhaps LSD transaxle. Let me know if interested
The car weighed 2575lbs with half a tank of fuel the last time on my scales but many more mods, parts added, removed, lightened, relocated for better weight distribution, etc...I am estimating around 2600lbs
VALUES listed do not include labor, just materials and parts.
Power mods: (NOTE, this is a direct turbo swap capable kit to the new version of the GTX GEN II, I can sell the car with that turbo if you send one to me or make other arrangements like engine swap plus bigger turbo, etc.....
*300+ WHP at 4700 ft elevation, 91 Octane, WMI, less than 20k miles on new turbo system(new GTX would net a lot more power and more bottom end for very low cost)
*DHM Quick Spool, GT2560R w/billet wheel upgrade, race grade catted DP, water cooled WG, recirc to DP
*DHM custom Ext Recric BOV, CPE Cold side IC pipe with WMI bung, heat wrapped.
*DHM tubular bumper and Race IC, *AEM WMI, tire well tank, pump and battery enclosures
*3"super efficient Vband SS exhaust, Vibrant 5" resonator, Borla muffler, muffler delete track pipe
*DIY real CAI, velocity stack in grill, mini keg filter housing, AEM dry filter, heat wrapped IC piping
*Cobb AP with Race Tuner, *Elite Engineering OCC, AN fittings, aluminum check valve.
*MW 50/50 mix, several containers included.
VALUE, $8,900
Cooling:
*Mishimoto radiator and aluminum expansion tank with AN fittings for turbo cooling with SS lines
*Setrab dual pass oil cooler, *Mocal Tstat plate, heat wrapped push on hoses, AN fittings.
*ABS sheet molded to seal IC, main grill, radiator, maximum flow through,
*Alternator cooling duct
VALUE, $1,400
Drivetrain:
*Quaife LSD, *Urethane Trans and engine mounts, *Cobb Rear Engine Mount
*Motul 300 gear lube since 293 miles, freshly changed 1k miles ago
*Shifter cable mount bushings, *Short shifter, very short and precise throws
VALUE, $1,400
Brakes:
*Front 11.75" 6 piston Wilwood BBK for 15" wheels, GT rotors, SS lines
*Rear, 11" 4 piston Wilwood BBK with Fastbrakes parking brake levers, GT rotors, SS lines,
*Wilwood BP-10 street pads, *Carbotech XP12 Front XP8 rear track pads
*Castrol SRF brake fluid, the best!*DIY Brake ducts fed from center of splitter
Spare Willwood BP-30 track pads, front
Spare Willwood BP-10 street pads, front
Approx $3500-4000 invested
Suspension/steering:
*BC Racing coilovers, 8/7k Swift linear spring upgrade, rides great!
*PowerFlex urethane bushings in full suspension and front sway bar
*Gun_Runner aluminum steering rack bushings
*-1.9 rear axle mod, -2.5 front,
*Steeda adjustable front sway bar links
*Custom modified race grade 5-way adjustable rear sway bar available for free, just needs a little work to finish the install
VALUE, $2,600
Wheels and tires:
(4) 15x8, 11.4lb, 6UL with 205/50/15 NeoGen tires, 90 or more tread left, amazing grip for an AS tire and very smooth riding.
(5) 15x9 Konig Helix with (4) 225/45/15 Rival S tires, 50% or better tread left, these are race tires for the street, super sticky!
Value approx: $2600
*Fenders rolled, *Gorilla short, open end security lug nuts, very low weight, I have used many sets on race tracks, no worries
*4x100 bolt pattern change, *ARP wheel studs
VALUE: approx $600
Interior: 175 lbs removed
*Autometer 3-way programmable shift light.
*No Pistons SS dead pedal, *Rear seat delete (will come with car if wanted, never used it)
*Spare tire and jack delete, I might have the jack, no spare though
*Alumalite rear cargo wall, aluminum framework, very low weight, very strong
*Alumalite cargo floor cover, tire well storage, WMI, battery, etc below, can safely carry tools, emergency gear and have a tank of meth/water and still have cargo capacity like a car with the false floor removed but I put in over 100 hours into this area alone working in AZ heat!
Never used Recaro package rear set included in price, negotiation of install is an option as well)
VALUE, $800
Body:
*Tripple R splitter, SS support rod,and brake cooling from center of car below bumper
*Alumalite 1/2 undertray integrated into TR splitter(second half for full understray included)
*Seibon RS style vented CF hood with Aerocatch locking hood pins
*Morimoto LED Fog lights
*LED full interior swap
*Rear QTR panels and hatch door professionally ultra low weight sound deadened
VALUE: $1,600
Misc:
*Viper long range 2-way alarm,
*rear mount gel cell battery,
*Window tint, 20%
VALUE: $1,200, installed and working perfectly.
NOTICE:
Total Mod parts value approx $25,000
Total to duplicate $35-40,000. (not including at least 1000 hours in labor)
Asking Price Just $15,900 or a bit less if you buy before the engine swap and DIY.
OBRO (or best reasonable offer)
PLEASE, seriously interested and qualified buyers and or leads only.
You are welcome to check out my reputation here of course but also I am the owner of RAAMaudio Inc, RAAMmat, Google me up and find out you are dealing with a stand up guy good for his word.
Thanks,
Rick
775-515-5355
DHM crash bar and race IC, Setrab oil cooler, velocity stack intake, cooling duct work.
15x9 with 225 Rival S on the front
15x9 Helix with 225 Rival S and 15x8 6UL with 205 NeoGen tires.
Mishimoto radiator installed, intake has been upgraded since this picture with aluminum front section, velocity stack in the grill area, much more insulation by the turbo and most of the air box.
Full length under tray, it has been trimmed back to the leading edge of the tires as just to much trouble to take it off all the time for upgrades, oil changes, etc. but I can include more honeycomb material to redo it as the full length one. The gap between the splitter and bumper cover in the middle of fhe car is now the duct for the brake cooling setup. Look further back and you can see the 3" super flowing exhaust I built.
VALUE, $8,900
Cooling:
VALUE, $1,400
Drivetrain:
VALUE, $1,400
Brakes:
VALUE, $2,600
Wheels and tires:
Value approx: $2600
VALUE: approx $600
VALUE, $800
Body:
VALUE: $1,600
Misc:
*Window tint, 20%
NOTICE:
Thanks,
Rick
775-515-5355
