Most of the advice on here is sound, but think some folks suggest to do things that are actually more labor-intensive, imo.
For example, I was reading up on how to replace the fog bulbs and most people suggested headlight removal. Absolutely no need for that. You simply pop off (one plastic snap on rivet and a torx bit screw(I actually just used an allen key)) the corner of the wheel well and they are right there. Actually, you can do the passenger side just from reaching underneath. However, the IC hose makes the driver side a bit tricky from underneath.
I know the headlight is easy to remove, but running my extended tubing with funnel is even easier. Besides, I already have it lying around, might as well use it.
Sent from my LG-LS777 using Tapatalk
