You should do a write up. Looks like a very clean install. Awesome place to put the display. Great job.
We took lots of pictures for the official install directions.
Sensor goes right behind the pcm on the battery box and there's only 12-15" of added fuel line. It's a little difficult removing the stock fuel line because of the angle, but not too bad.
The hardest part of the install will be running the sensor signal wire from the engine compartment through to the display. I already had wires in place for other things, and it was still a little tricky.
I'm going to run this setup for a few weeks before we finalize it.
Sent from my ONEPLUS A3000 using Tapatalk
