So, things are getting confusing and have a trio of concerns:
1. Can't get a clear answer on wiring pins. According to these pics we shouldn't have to move anything for DRL in Low at all times, right? With one pic of each side of the connector, so they are reversed, we are already wired in pin 6 for DRL on low... Then why would we need to move the pin from 3 to 8, which is supposed to be for the leveling motor? Is the Euro wiring labels incorrect on the right pic? The bottom is cut off but shows that pin 9 is for DRL High. I truly am on information overload here and don't know what to believe any more. Also just can't believe no one tried ForScan before coming up with a complex wiring harness just to get low-high proper DRL functionality. I'm not afraid of moving pins around but again, can't figure out what to believe. For this I'm going to plug them in as is and try ForScan and see what happens, otherwise assume the Euro wiring pic labeling is wrong, otherwise I don't get why you'd have to move the existing wire already in what's labelled as DRL low to Leveling motor to get DRL low...
2. Still not sure if an H7 full HID conversion kit will be completely plug and play or not or need mount plates or anything. I'm REALLY wishing now I jumped on the Hikari Ultra LED when they were on flash sale plus a 10% off coupon for $63 total, UGH... Still might just return the HID's and get the Katana for around $45 that do work pretty well.
3. AAAAND the freaking leveling motor, how it will likely not be set right as its intended to. Reading far too much crap on this has me really worried.
Where to go from here:
First, once housings arrive, try to install the H7 HID kit as is and see if I get a proper mount in the bulb seat. If they don't fit right, try contacting DDM Tuning support since they were nice and helpful and let me know they had great results with their kit on another FiST with Euro conversion.
Second, assuming I can get the bulbs mounted properly, just hook them up and try them, see what happens. Then try ForScan and see if any of the options there change anything. If they don't, just do the one wiring pin as shown in the left pic/front page here and see if the harness kit becomes available, who knows.
Third, if the leveling motors are set to a bad position to where I can't adjust them, I don't know... Then, honestly, what I may do is have these GDMF'ing things sit until I have the money to get the projectors upgraded and get the levelling crap fixed with the headlights split. Then I'm out the money for the H7 HID kit when it's like another $200 for a whole projector upgrade with new proper D2S bulbs and that's not even the higher end stuff, that's just the DDM Tuning stuff which is OK but not the greatest...
I'm SERIOUSLY regretting buying these now, there is just TOO many issues and not enough clear knowledge on this stuff along with no budget to just throw money at the problem... Maybe I'm worried for nothing and it could end up completely 100% PnP as long as I'm happy with the DRL's on low, with maybe the one pin swap.
