Container shipping really is dirt cheap, I shipped four 1500 lb pallets from the other side of the US to Singapore 4 or 5 years ago for $800! At the time the best deal I could get going from dock to dock meaning forklift required cost nearly the same per pallet and that was shipping 10+ pallets from the same place to Utah, I could never quite figure that one out and could not get an international shipper to even quote dock to dock within the US.
Bronx, when you drop the weight going to 15x8, 11.4 lbs wheels you will be amazed, even if you ran 14 lb 17x8 you would still find a considerable improvement going down to the lower weight and more of the overall rotational mass moved inboard.
As mentioned many times the weight savings effects all aspects of performance, acceleration, braking, handling, ride, wear on the chassis and can improve fuel mileage depending on how you drive of course As for the brakes, going down approx 25% over stock weight and moved further towards the center of the rotation will significantly improve the brakes effectiveness and lower maintenance issues.
There simply is no other mod one can do to improve all aspects of the car so significantly.
