I got 'em from Amazon. They're OMP OA/1000 and I couldn't be happier, especially for the price. The install is pretty straightforward and I probably made it harder than it needed to be because I didn't remove the gas pedal assembly. I couldn't get a good angle with my drill and really struggled with it. If you spend the 3min to unbolt the pedal assembly, it will probably save you 30min overall.
Installed a Mountune Quick Shift kit. It feels so much better now, closer to my TSX. Install was a little more difficult than expected but it was well worth the effort.
Picked up an Amra Speed carbon fiber intake and proceeded to drop it on the ground and crack an edge D'oh . This completes my expensive and unnecessary intake system . I couldn't resist the carbon fiber bling but after installing it I am not sure if I am going to keep it for long and will probably go back to my Mountune setup soon.
The fitment and over all design leaves a lot to be desired. The outer heat shield mounts in the same points at the factory box but then the cone filter itself floats in the middle (or at least is supposed to). Meaning the intake piping from the cross over on is just lose and has no hard mounts. I had previously thought the heat shield, filter element, and elbow were mounted together but nope. I have not drove it yet but I don't think the intake temp be effected too much as the filter draws air pretty far down in the bay. We will see.
^^^Does anyone who owns these intakes ever use a large diameter ducting hose from a grille/fog light opening, or a duct from our under bumper 'air dam' thing into the bottom of that cannister?
I thought a hatchback is supposed to have a lot of room? I can't even fit my bike in the back with one of the wheels still on it. Oh well, roof rack on the way!
I can fit my old larger frame with extended seat-post ten speed with the 27 x 1 1/4 tires attached. Just have to move the passenger front seat all the way forward.
I actually managed to fit my 29er in with the front wheel removed by sliding the front seat all the way forward as you mentioned. But anyway, my roof rack and bike rack should get here Monday [emoji14]
It came down pretty hard a couple times today on our side of the bay. Got to test my new rain jacket that showed up in the mail this morning. And a little throttle-off oversteer
The fit/weight is very similar, but I can no longer use the threaded rod that clamps the wheel down. The fit is very tight already, so hopefully it will stay quiet.
Installed Damond OCC. Not too bad of an install thanks to previous installers giving some good tips.
Switched out the stock spark plugs for some NGKs one step colder. No drama at all if you have a decent spark plug socket.
Since I already had the car on a jack stand with the passenger wheel off I was going to also try to install my GFB DV+. But damn - no way I was reaching those bolts without an extension and longer allen key than what I have. So, off to the store today or tomorrow and will put in the DV+ another day.
Definitely recommend a filter socket. I think I got mine for $5 from autozone. It takes a bit of work to get it and the wrench around the filter, but once there, easy to torque the damn thing off.
