Heyo! Just looking to get some insight from everyone on two different wheels on TireRack... I'm partially biased towards the first set only because of the color (Car is white, going for black and white 'panda' themed haha), but I keep thinking about the other set because it just sounds too good to be true spec wise, and I could always just plastidip them black as well. Both save some weight over the stock wheels, so their's a slight performance plus to both. Anyone heard about bending problems with either brands? These would be street use wheels, not track use. Thanks!
Option A)
Sparco Trofeo 4
Offset:47mm
Backspacing:5.866"
Bolt Pattern:4-108
Rec. Tire Size:205/40-17
Weight:18.4 lbs.
Finish:Black Painted
Construction:1pc. Gravity Cast
Finish Warranty:Not Available
Manufacturer Part #:W2906400153
Manufactured in:China
Option B)
Kosei K5R
Offset:42mm
Backspacing:5.669"
Bolt Pattern:4-108
Weight:15.9 lbs.
Finish:Light Grey Painted
Construction:1pc. Low Pressure Cast w/Flow Forming
Manufacturer Part #:K5R772LG
Manufactured in:Thailand
Thanks!
-Matt
Option A)
Sparco Trofeo 4
Offset:47mm
Backspacing:5.866"
Bolt Pattern:4-108
Weight:18.4 lbs.
![](http://www.ozracing.com/images/products/wheels/trofeo-4/matt-black/02_sparco-trofeo-4-matt-black-jpg%201000x750.jpg)
Option B)
Kosei K5R
Offset:42mm
Backspacing:5.669"
Bolt Pattern:4-108
Weight:15.9 lbs.
![](http://www.tirerack.com/images/wheels/kosei/kosei_k5r_lg_pdpfull.jpg)
Thanks!
-Matt
