I took the car or this morning and under normal driving while the car is still cold I will get a flutter 3-4 times, after that is a normal whoosh which is good.
I checked out gfb website and got this info.
Blow-off valve doesn't flutter, it makes a 'whoosh' sound:
If a car is making a fluttering noise when venting at high rpm and boost, then the BOV isn't doing its job. Contrary to popular belief the noise is actually emitted from the turbo, not the BOV itself.
With an aftermarket BOV fitted some non-detrimental low rpm fluttering does characterise certain cars (as mentioned above) particularly where a larger turbo and intercooler have been fitted.
When properly adjusted, the valve should make a clean PSSSH or Whoosh sound when venting a significant amount of boost. If you want your BOV to flutter a bit, try increasing the spring preload by turning the adjustment clockwise. It's perfectly safe to set your BOV up to cause some low-rpm flutter, as long as it vents with a whoosh at high-rpm and boost.
Obviously the dv+ isn't adjustable but I believe mine is working as intended. I am guessing the lubricant I used is sticky on cold starts and once it gets moving it's all good.
I still wonder why yours (rastok) flutters all the time.
