I have a question for those who went down to 16" wheels- do you feel that you lost some of the crisp turn-in, was the steering and handling less precise, and did the ride improve significantly?
I am concerned with function over looks,so my primary goal in changing wheels would be to reduce unsprung weight. I think that's the single best thing you can do to improve performance.It would seem 16's would be better than 17's for that.however, I would probably get Pro Race 1.2's. the 17x7 in that weighs about 5 lb. less than stock, great. A 16x7 in that wheel only weighs .7 lb less than the 17,according to their vendor's forum. But here's where it gets interesting: when I look at 205/45-16 tires,most weigh 2-3 lb. MORE than the 205/40-17 oem's, I guess because of the taller sidewalls. So the way I would do it, all-important unsprung weight is lower with 17's!
-I do feel some small but noticeable "crispness" was lost. The tread and section width of my SC2s may be slightly too wide for my 7" width wheels. (i.e. "meaty" vs. the preferred "slightly stretched")
-Handling and steering are no less precise/predictable (so far as I am personally able to tell). Took me ~10 mins to adjust myself to the new setup. (FYI - alignment did not need any adjustment)
-Significant increase in comfort.
-Significant increase in confidence, meaning for me, on the streets, I cannot find the limits of grip. (Some of this is certainly going from end-of-life tires to fresh, new ones)
-If I had been willing to pay double, there are RE71Rs that weight exactly the same as 205/40-17 OEM 050As, 19lbs (and the overall specs look awesome). My SC2s weight ~21lbs and that's good enough for my casual street-only usage, but I did absolutely compromise on the weight increase in favor of saving $$$. (FYI - 205/4516 Hankook Ventus RS-3 are ~20lbs)
