Make sure you can get track tires in the size you want to run before going to the 17x8 setup, that is a big issue with 17's on this car, not many tires to pick from.
There are some flow formed 16's in the works but no date expected yet, 7,8,9 wide, 4x100, good offsets for the car(9's require rear camber change and rolled and pulled fenders all around) They should be in the 14lb range and fit the WW BBK, they are theh Advanti Storm made my Konig
My 15x8 and 15x9 wheels fit over my front and rear DIY BBK with 11.75 front rotors, it is becoming available as a kit.
I might switch to 15x10 front and 15x9 rear, 245 and 225 race tires, 6 ul wheels or go nuts if any good flares every come out, 15x11 6ul and 275 race tires all around
I do not like either of the red cars setup though if had to pick it would be the one with wheels that do not likely weigh 26lbs or more and barely any tire on them.
I agree, to each his own, I just prefer to setup my car to drive it more than look at it
