Now that I have driven about 600 miles on it and then taken it off. If you are into making your car the most uncomfortable car you have ever driven, you should install the RMM. Anyone on this forum who tries to tell you otherwise is full of themselves.
This thing, locks down the motor and it transfers every vibration back through the car. Everything in the car was shaking and everything was vibrating. It was like having a large cam installed in the car. As a daily
While I respect your opinion and experience with Fiesta ownership, I have to disregard some of your review. Firstly, 600 miles isn't nearly enough time or mileage to give a fair evaluation of a rear motor mount. Most mounts require at least 1000 miles of break-in, or even more in some cases before they will calm down. Secondly, I experience NONE of the vibration like you are experiencing. Everything was shaking? When? At idle or past that?
The difference between with and without, with, traction is a little better. but, maybe not, with the RMM on the car, I laid down a strip of tire marks over 30 feet for the first time since I bought the car. Without the RMM, I am unable to lay down that 30 foot skid mark. That seems to tell me, better traction without it.
I believe this is a sign that the rear motor mount is doing it's job. You can deliver more power because you aren't experiencing any power being lost by movement of the engine.
I want to give my input on this subject, as I have a Breedt rear motor mount as well.
I feel the Breedt RMM has been given a bad rap here. As mentioned, not many people have this mount and I feel that has to do with two things. The first, is that Breedt does almost no advertising. They have a forum prescence but only on select forums and rarely post, mostly showed up after releasing their mount and then disappeared. Breedt is also not a performance company, but a machining and tool design company who happens to make a few automotive products.
Secondly, I feel that Cobb is such a big name performance company that naturally, more people will purchase just from that alone. And they do a lot of advertising as well and participate in the community.
Now that that is out of the way, I also don't feel that any particular mount is "bad." Every mount has a stiffness or durometer rating. With higher durometer is more harshness and most companies with the higher ratings don't necessarily claim their mounts will be good for daily driving. Some mounts get a bad rap because some people may not do the research prior to purchase and just grab a known name brand or a mount their "buddy" bought.
Concerning the Cobb, they claim a stiffness rating of 68A for the large bushing and 85A for the smaller bushing. I couldn't find the Mountune RMM stiffness rating on the product page. I was particularly interested in the Breedt mount however because it comes with a 40A large bushing, which based on my research, is the softest rated bushing for a Fiesta RMM on the market. CP-E is stiffer than Cobb as well as the Boomba I believe.
I like the idea with the Breedt that you can switch to a 60A bushing (which is included) if you want a "stiffer" experience or decide you will be racing more. It also is better in the long term because like anything, bushings eventually will fail, so on the Breedt you can take it apart and replace the mount when it gets warn. You can maintain it, while you would have to replace other mounts entirely. I opted to stick with the softer pre-installed 40A bushing as I wanted as mild of NVH as possible. While it has the softest bushing rating, keep in mind there is no smaller bushing, the mount is solid billet besides the large bushing. I feel this may slightly negate the lower durometer bushing, however the smaller bushing side is typically the side with the most movement on the stock mount, so this makes sense as to why the manufacturers above put a higher stiffness bushing on that end of their mount.
My impressions have been good so far. Install was easy, fitment was perfect and the quality is great. At first, I was put off by the noise but almost within the hour it tamed down. Even a week after, I noticed a difference at how it calmed down. At idle, it feels like stock, even with AC on. There is a "sweet spot" where the vibration is worst and that is between 1000 to 1200 RPM where the dash vibrates. I'm not sure where your "excessive vibration" issues you mentioned are coming from. The main difference that I've experienced is engine noise. I feel that this is because of the increased resonance, the mount doesn't absorb sound like the stock mount would. So overall the engine is louder, but in a good way. It sounds more aggressive, almost like there was an exhaust added but the noise is from the front. I personally like the increased engine noise. It's not loud by any means, just more audible. As far as feel when driving, like most mounts, it does a great job at delivering power better and forcing you to pay attention to the wheel more, as the torque steer is more substantial.
I have taken a small road trip with it and driven everyday commuting around town for a few weeks now. I believe I have almost 400 miles on it. It seems to get more tame by the week, but I've been waiting for a final consensus because I want to reach 1000 miles before giving my final review.
If you want more info or detailed pictures of the mount, feel free to look at my install/review thread. Another member on here, [MENTION=762]BostonDriver[/MENTION], also has a Breedt mount and loves his.
http://www.fiestastforum.com/forum/threads/8754-Breedt-motor-mount
