This looks to be VERY good news. [MENTION=2672]fST[/MENTION] just sent a picture of where the bulb goes into the headlight projector.
There will probably be just enough space for the LED bulb. It may help that I still have a portion of my bulb shaved down though. I will keep everyone posted on this. If not, I will go with the whitest halogen bulb I can find (begrudgingly).
Yes they are plug=N=Play except to move one wire on both of the car headlight connectors.
I designed the other wiring setup (shown on the other site) but it is easier to just move our parking lamp + wire (green/brown) to the empty space where the LED + (purple) should be.
This takes about 10 minutes per side (OGT) and makes the LEDs, the parking lights.
When you did this did you have to drive a hole to put the green/brown wire into the LED+ slot of the headlight connector?
[MENTION=2672]fST[/MENTION] seems to not have an opening in his connector in that slot.
I did this some time ago.
As I recall there is a small white plastic piece that must be removed from the pin location in the connector so that the wire can be inserted.
As I recall there is a small black plastic piece that must be removed from the pin location in the connector so that the wire can be inserted.
The one with the red arrow. I do see what looks like white plastic pieces in the unused slots in that pic but I swear I don't have them, just the black tabs for each slot.
I can't get the pin in the LED slot, or any other slot for that matter. It's like it's being blocked. I couldn't really tell what is blocking it though.
Unfortunally this is something I cannot help you with without seeing it first hand.
Usually there are little tabs that hold the pin/socket in place that is a molded part of the connector itself.
So is the connector becoming the issue with these? Is it the vehicle side or headlamp side? They sell these via uk Ford for about $250 American. ...shipping I'm thinking would be about $150-200.
