I am considering buying a set of these euro factory headlights. Besides the LED function, is the rest plug and play?
If you'd read the original thread on the topic, you would know the answer to this question.
Also seen here:
http://fiestast.net/threads/2014-na-eu-headlight-swap-all-you-need-to-know.968/
YES, they are direct bolt in and only the LED function needs to have ANY wiring whatsoever done, and making the LED work is super duper easy, even an idiot can do it (I'm the idiot who did it, after all)
Bulb conversions:
Front Direction Indicator
NA Spec: PY27/7 (3157)
EU Spec: PY21W (7507)
Note: NA uses a wedge bulb, EU a bayonet bulb. EU bulb is single filament as well.
Headlamp High Beam
NA Spec: H1
EU Spec: H1
Headlamp Low Beam
NA Spec: H11
EU Spec: H7
Front Fog Lamp
NA Spec: H11
EU Spec: H11
Ankylosing Spondylitis
www.Ankylosing-Spondylitis-Info.com
Find Info About AS Symptoms
And What You Can Do Today.
Side Direction Indicator
NA Spec: WY5W (T10)
EU Spec: WY5W (T10)
Note: This is the bulb in the side mirrors. "5W" refers to 5 watt.
Rear Direction Indicator
Brake and Tail Lamp
EU Spec: P21/5W (1157)
Reversing Lamp
NA Spec: W16W (T10)
EU Spec: W16W (T10)
Note: "16W" refers to 16 watt.
License Plate Lamp
NA Spec: W5W (T10)
EU Spec: W5W (T10)
Note: "5W" refers to 5 watt.
Part Numbers:
Headlights (Projector headlights w/ LED DRL in LHD beam pattern):
C1BB-13W030-CD / 1831485
C1BB-13W029-CD / 1831585
American Express- Savings
There's No Need To Switch Banks. Open A 0.90% APY Account Today. AmericanExpress.com/PersonalSavings
Wire Harness Pigtails:
CU2Z-14S411-ADA or WPT-1279
Wire Pinouts:
[?IMG][/B]
