Thread Starter
#161
Looking at 7k front, 5k rear...Step between full on bspec and autox, with a soft enough rear to not get super happy rear end under braking/corner entry...Max rotation isn't nearly as needed for road courses vs autox...Since I do some autox for fun occasionally... Now if be willing to run the 5/3 setup for a year, unless you can set me up with the higher rates initially...
Because the fiesta has had issue with stiffer sway bars cracking the front mounting points I'd rather run a higher spring rate and less bar (not really needed out back with the fiesta's rear stiffness already) then the softer rate and reliance on the swaybar to manage the bulk of weight transfer...
Sent from my Nexus 6 using Tapatalk
At this spring rate, you are already over the 2.0Hz wheel frequency mark.
You can go higher, but that's getting into the custom build GT1 area.
MeisterR dampers have proper compression force, so we don't need to use artificially high springs rate to compensate.
Jerrick
