Well its time to start planning to by a new set of summer tires for the FiST, my OEM Bridgestones RE50A don't have much tread left, under 3/32. Got about 25,000km (15,000miles) on them which doesn't sound like a lot but with the soft rubber longevity is the price you pay for higher traction.
Trying to decide between the Bridgestone Potenza RE050A or Pirelli PZero Nero in the stock size of 205/40r17. I mainly use my car for daily driving but might plan to do a bit of autocross this summer or head out to the drag strip. I want to stay in the Max Performance Summer category and while the Extreme Performance Summer tire is tempting don't want to trade off too much wet traction performance. Because I live in Canada my options seem a bit more limited for the price I want to pay. Can get both of these tires from Costco at a some what reasonable price, as there's manufacturers rebates for both right now.
Had considered the 215/40r17 Dunlop ZII's but these are in the Extreme Summer category and are 22lbs with a diameter of 23.8", I could see these lasting shorter than the RE050A as they come with 8/32 of tread vs 10/32.
The other tire have considered and previously owned are the Yokahama S.Drive 205/40r17 and would last longer than both the RE50A and PZero Nero would be giving up some level of traction.
Pros for RE050A:
- 19lbs (Lighter than PZero Nero by 1lb, may not be a big deal)
- 23.46" diameter (stock oem diameter)
Cons for RE050A:
- 140 tread wear (probably won't last as long as PZero Nero)
Pros for PZero Nero:
-220 tread wear (should last longer than RE050A)
Cons for PZero Nero:
-20lbs (1lb heavier than RE050A)
-23.7" diameter (For some reason their diameter seems bigger than any 205/40r17 I've seen made by any manufacturer, normally its about 23.5")
Consumer Reports (sometime ago) scored the PZero Nero pretty low, then again sometimes I've wondered about their testing methods.
Tire Comparison: Bridgestone Potenza RE050A / Pirelli PZero Nero
User scoring: Bridgestone Potenza RE050A / Pirelli PZero Nero
The PZero Nero tire are slightly higher rated on TireRack.com by both their testing and consumer feedback, though the consumer feedback I don't take too much weight into as most people doing the reviews don't know a hole lot about tires (ie complaining about the short tread life, duh these are high performance summer tires, there's trade-offs to be made to get that extra grip vs tire life)
I'm sort of leaning towards the Bridgestone RE050A but the Pirelli PZero Nero do look tempting, what do you guys think?
Pros for RE050A:
Cons for RE050A:
